connect to internet and access Marketplace
#21
This is strange, It looks like something on your router, Check firewall.
i'll get a new computer I guess it's easier
thanks for the help Smile
Firewall on your router not PC.
Hello everybody !
facing same issue with my LM5p2-DW1 - can not connect to app store :-(,
trying with different wifi routers and with disabled antivirus as well.
Still can not...
Check if you can ping gateway and DNS IP addresses from LM.
(20.05.2021, 05:26)admin Wrote: Check if you can ping gateway and DNS IP addresses from LM.
Can you ping the gateway from your PC?
(20.05.2021, 08:21)Daniel. Wrote: Can you ping the gateway from your PC?
FYI,
LM connected to laptop and laptop connected to internet by wifi, wifi adaptor IP & DNS settings as default (on auto).
LM must have internet connection to install apps. It needs to be connected to the router not to your laptop Ethernet.
OK , thanks - will try it.
you sure about your gateway? *192.168.0.100?
Check your netwerk configuration.
open CMD or Powershell (in windows) and type ipconfig
check if
subnet mask
gateway
are the same.
