Threads: 17
Hi:
Several days ago, when I try to connect with the main system, the browser doesn't show anything, it is blank. No problem with scada-vis.
Which can be the problem?
Threads: 31
Clear browser cache, reboot might also help.
Threads: 17
I've done it and nothing.
Looks like the micro SD card is corrupted, the only solution is to replace it.
Threads: 17
But scada-vis, schedulers, scripting,... everything are correct. I've tried with my movil and I've connected. I've tried with another LM and it happens the same way.
In this case this might be firewall/antivirus issue. Try disabling them and see if it works.
Open browser dev tools (F12) and see if you have any errors in the console
Threads: 17
22.12.2020, 16:22
(This post was last modified: 22.12.2020, 16:35 by Angeles.)
ReferenceError: Ext is not defined
Ext.grid.BoolClsColumn = Ext.extend(Ext.grid.Column, {
This not happen with other LM, so my browser is not the problem. It only happens with two, for now
I've tried another computer and the same thing happens.
Then it's a micro SD card corruption
Threads: 17
22.12.2020, 16:52
(This post was last modified: 22.12.2020, 16:52 by Angeles.)
But if it's the SD fault, why can I see it on my mobile?
and on a tablet, no pc.
Threads: 17
apparently it opens correctly
Can you provide access to your PC via TeamViewer?
Threads: 17
Right now I'm leaving the office, it could be the 28th, next Monday.
Can you tell me your email to send you the connection?
Threads: 17
sorry, but this is a public area and I can't send connection data.
