Airplay scratching problem
Hi!
I have problem with Airplay. Attached audio sample: there are playing from amatilinea then from macbook and then again from amatilinea.
Looks like network speed problem, but I have 1Gbps LAN with stable link + Ubiquity Pro at 5Ghz.
Network diagnostic window shows normal speed for about 1-2Mbps when playing.
Playback from USB flash drive works great.
Model:
HW: i.MX6
SW: 20191001
Tried update, play with settings, different devices, LAN ports, cables.
Any advice how to fix?
UPD: Sorry, re-added sample
.zip   airplay_problem.m4a.zip (Size: 224.1 KB / Downloads: 1)
Spotify works normal, but not AirPlay
I just tried Airplay by playing music from youtube on iphone, just works. Did you turn the Airplay ON?
Yes, if I turn it off I can't connect to device via Airplay.
