Threads: 13
Goodmornig,
is it possible to use an usb-knxrf interface to put LM5 and the KNX RF system in communication?
Best regards Cristian
Threads: 22
This is not possible, you need an external gateway
Threads: 22
Yes, that's right. What kind of RF devices do you need. Have you considered using ZigBee instead?
Threads: 13
my intention was to send group objects to a JU1 rf using a UIMrf directly from Logic. But if it's not possible I will put the gateway. Thanks anyway
Threads: 2
How much is "ready to use" the zigBee adoption on LM?
Threads: 22
At this point you can control ZigBee lamps (dimming, rgb, color temperature). Switches, sensors (temperature, humidity, water leak etc), motion and open/closed detectors are also supported. Soon we will add support for locks and heating control valves.
