Threads: 9
I`am probably blind, but I can`t find value widget with feedback..
Want to controll heating modes with value byte.
GIA
Best Regards
NewBee to wiser
Threads: 31
Please explain which visu you use and what element.
Threads: 9
using Touch 3 (Wiser for KNX)
Can`t realy find the correct widget that supports byte-values
GIA
Best Regards
NewBee to wiser
Threads: 31
Then I don't understand, this element has object for control and status for feedback.
Threads: 9
27.01.2021, 21:40
(This post was last modified: 27.01.2021, 21:41 by GIA.)
(25.01.2021, 13:00)Daniel. Wrote: Then I don't understand, this element has object for control and status for feedback.
Hi, yes 1-bit feedback
(25.01.2021, 13:11)admin Wrote: Use the last element in widget creator to map byte value to an icon:
Yes, you are correct, that did do the trick
GIA
Best Regards
NewBee to wiser
