Threads: 163
Hello
Is it possible to link a text to the description of the object?
Let me explain a text that reads the description of the linked object and represents it in visu as text?
Can you explain the purpose of this in more detail?
Unfortunately object description is not available in the visualization directly. You will need some extra server-side .lp files to access it. Using a separate 250-byte should be much simpler.
Threads: 87
in one project I did as admin recommended - used 250-byte objects for button description.. I put all of them at init script - so names loaded when PLC started.
Project still not finalized, some buttons has "reserved" names. But quickly and easily names can be changed/upgraded from one place..
Alex
