push alarm
Hello
I would like to know if the alert manager is able to send push notifications, in case of an alarm, for example on mobile devices.
Thank you
No but as long alert is generated by script you can use other push notifications method, like this
https://forum.logicmachine.net/showthread.php?tid=1119
or the telegram integration
https://forum.logicmachine.net/showthrea...1#pid17111
You can use a resident script (sleep time = 0) to catch all alerts and forward them to any external service:
if not client then   function alertcallback(source, text)     log(source, text)   end   client = require('localbus').new()   client:sethandler('alert', alertcallback) end client:step()
(05.02.2021, 08:32)Daniel. Wrote: No but as long alert is generated by script you can use other push notifications method, like this
I am trying to use push notifications via the cloud but don't let me register new user
Did you try to register here?
https://cloud.logicmachine.net/user-mana...auth/login
(05.02.2021, 09:29)Daniel. Wrote: Did you try to register here?
OK perfect
