CAN bus communication with VRV system
hello,
some VRV systems use CAN bus to communicate between indoor and outdoor units like GREE.
could we use the LM CANx protocol to communicate with the VRV system instead of using Modbus or BACnet gateway?
regards,
No our canX use only can as medium but protocol is different.
LM has CAN FT while most other devices have CAN FD. The protocol must be known as well because CAN does not mandate data format.
(10.02.2021, 14:11)Daniel. Wrote: No our canX use only can as medium but protocol is different.
(10.02.2021, 14:14)admin Wrote: LM has CAN FT while most other devices have CAN FD. The protocol must be known as well because CAN does not mandate data format.
So the use of CAN FT only for LM products?
In theory it's possible to use any other CAN-FT products but for this you need to remove the CANx app and write all the communication logic yourself.
