BAR CHANGE SIZE 0 to 100%
How could you have in a visualization a bar that goes up and down in function of a variable from 0 to 100%
See this thread for a similar example: https://forum.logicmachine.net/showthread.php?tid=3075
For horizontal mode you need to change the height property to width in both CSS and Custom JS.
thanks, but i need change in the order side, ..from bottom to top . Now i can do it but down to up.
Set additional class is bar. This single example will work on multiple elements with the same class.
$(function(){
  if (typeof grp == 'undefined') {
    return;
  $('.bar').each(function(index, wrapel) {
    var wrap = $(wrapel);
    var addr = wrap.data('object');
    var el = wrap.find('.icon');
    var height = el.height();
    var init = true;
    grp.listen(addr, function(object) {
      var value = Math.round(object.value * height / 100);
      el.css('overflow', 'hidden')
        .css('height', value)
        .css('margin-top', height - value);
      if (init) {
        init = false;
        setTimeout(function() {
          el.css('transition', 'height 1s linear, margin-top 1s linear');
        }, 10);
    }, true);
