Wiser for KNX how to visualize widget on bottom
I wonder if it's possible to put a widget under an image, for example I need to put a SVG icon on top of a RGB widget, is it possible with CSS?
Thank you for your help
This can be done via CSS if both elements have the same parent container element. See this: https://forum.logicmachine.net/showthread.php?tid=1826
Thank you!
