23.03.2021, 08:47
Hi.
If you are on a normal network there is an easy option to install the FB Editor package.
But I have one LM5 (LM5Lp2) that can't reach the "package repository" the FB Editor can be installed from, this is because of network restrictions on the LAN.
However I have remote access to it, and can use the install from file option if I only had the .ipk
Have searched the forum but am unable to find an .ipk package for this application.
Have also checked under extra packages in release-threads but no luck
Alternatively if I knew how to extract a 3-byte like the format it comes in LM5 ie (8:07:30, Tuesday) into separate objects for hour, minute and day it would make my initial problem go away
- Odd Egil
- Odd Egil
