FB Editor 2.0, can't install package due to network restrictions
Hi.
If you are on a normal network there is an easy option to install the FB Editor package.
But I have one LM5 (LM5Lp2) that can't reach the "package repository" the FB Editor can be installed from, this is because of network restrictions on the LAN.
However I have remote access to it, and can use the install from file option if I only had the .ipk
Have searched the forum but am unable to find an .ipk package for this application.
Have also checked under extra packages in release-threads but no luck
Alternatively if I knew how to extract a 3-byte like the format it comes in LM5 ie (8:07:30, Tuesday) into separate objects for hour, minute and day it would make my initial problem go away
- Odd Egil
Can you explain what this script is supposed to do? Do you want to take a time from an external object or use LM internal date/time?
(23.03.2021, 08:49)admin Wrote: Can you explain what this script is supposed to do? Do you want to take a time from an external object or use LM internal date/time?
I had in mind to use the objects to use in a kind of weekly schedule with lua
Tried to do this with a scheduled script but that didn't work for me
But in general:
Mon, tue, wed, thu & fri @ 08.00 1-object should go true
Mon, tue, wed, thu, fri, sat & sun @ 17.00 1-object should go false
Why don't you use Schedulers for this?
(23.03.2021, 10:31)admin Wrote: Why don't you use Schedulers for this?
Sorry, my bad
Didn't create one as the first popup didn't seem to make any use for me
But after I created one scheduler, I got another kind of popup
And THIS looks much more promising
Blush
And just as an update, that worked 100% as I wanted it to do
Another +1 for the LM
