Threads: 31
If you successfully installed it then just clear browser cache. There is also bacnet client app in the store.
Threads: 31
If you have the app then you don't need this tab, app does the same. App is in the home page.
To install the bacnet package you must go to System-Syetm-Packages there is + on the bottom.
https://dl.openrb.com/lm-20-imx6/pkg/gen...8_imx6.ipk
Threads: 31
This is bacnet server. If you want to use client just keep it disabled. Both can't work at the same time.
Threads: 31
Hard to say, Try Yabe on PC.
Threads: 8
Did you set the export flag on the objects you want to expose?
Do you see the objects under system -> network -> bacnet objects?
Threads: 31
Erwin this is client not server.
Threads: 31
When you use client do not touch server. Otherwise nothing will work.
Threads: 31
Our client is designed for small amount of objects, It won't work well with big amount. If the app won't work you can try doing it manually by script.
https://openrb.com/logicmachine-as-bacnet-client/
