Threads: 33
Hello maybe I missed something, but are schedulers already accessible from the cloud?
If not do you plan to implement this much missing feature?
Thank you.
Schedulers are not implemented yet, but we have plans to add them later on
Threads: 30
If you use Mosaic Beta then end user is able to create Scene and use it with the scheduler(not the same as in LM, this is using script scheduler).
https://youtu.be/LB96DfbQzM0
Threads: 22
Is there an issue with the new cloud update from yesterday? The mosaic visu is not recieving or sending any values after the update.
Threads: 30
It works fine, check if you have any errors in LM cloud app
Threads: 30
Sync again.
@Krstfr2k, post a screenshot of the LM cloud app logs
You can already specify username/password in the URL. It won't work locally but will work over cloud.
But what for? It won't make the camera stream work locally when the final URL has to be in user:password@IP format.
RTSP is not supported. The camera must support providing single JPEG snapshots via HTTP.
