SpaceLynk "import neighbours" issue
we have two SpaceLynk by Schneider Electric and we're trying to import some group objects from one to the other,
with someĀ one bit objects no problem, but when we try to link some bigger values (modbus reading from a multimeter for example) the one who's polling modbus read and update the values, the other one in which we imported those groups doesn't.
We're doing something wrong? Any suggestion?
Thank you in advance for your help.
You are probably using virtual addresses, those are not exposed on KNX IP so the other controller is not getting the values.
Use adresses 0/x/x to 31/x/x
Yes, thanks! Now it works!
Just to know, is it possible to expose virtual objects?
No, that is why they are called virtual, they are meant to use for internal usage to minimize the load
Got it, thank you Erwin
