Bacnet Server
Hi, is there any way to define some bacnet registers as "read only" using LM as Bacnet Server?
I've enabled bacnet server, mapped some objects and read/write from client is working, but I need that some of them to be read only.. Is it possible?
Not possible directly. BACnet server uses "Binary/Analog value" objects which can be both read and written. You can use virtual objects that follow another object value via a script. These virtual objects will still be writable from BACnet side but changing them won't affect the original object value.
(08.04.2021, 13:45)admin Wrote: Not possible directly. BACnet server uses "Binary/Analog value" objects which can be both read and written. You can use virtual objects that follow another object value via a script. These virtual objects will still be writable from BACnet side but changing them won't affect the original object value.
Ok, I'll try!
Thanks!
