Zigbee gateway integration
(21.11.2022, 08:19)admin Wrote: This thermostat has a lot of custom properties that we will not implement. Some standard properties like setpoint, temperature and power measurements can be implemented.
Ok,
I need at least setpoint, room temperature, floor temperatue, and power measurement (watts). It has also an accumulated energy consumtion property in KWh
Most of the other properties are accessable from the setup menu on the thermostat.
Carl
Can I connect the Rs232 zigbee together with the usb stick and move the zigbee devices one by one or do I have to disable/remove the usb stick first and re-build the zigbee network in one go?
Disconnect USB dongle, connect RS232, change connection mode in the app to RS232. Do not change any other network parameters. You will also need to power down all ZigBee devices while changing to RS232. Otherwise the network formation will fail.
(03.04.2022, 19:44)clue9 Wrote: I think i need to follow up on post #110 #111 #119 in the search for a solution for getting the Develco on/off plugs working.
There have been several updates to the zigbee app and none of them have sorted out the missing ability to control them og retriving status from them. I understand the powermetering function is not ready, but it shoud be possible to get them working in means of control. I have reset the devices several times and re-included them to the zigbee network in hope for a soulution for getting them working.
Manufacturer: Develco Products A/S
Model: SPLZB-131
Device type: Router
Power source: Mains
Receive when idle: Yes
Endpoint 2
Profile: 260
Input clusters
- Basic (0)
- SeMetering (1794)
- Identify (3)
- Alarms (9)
- HaElectricalMeasurement (2820)
- OnOff (6)
- Groups (4)
- Scenes (5)
- DeviceTempCfg (2)
Output clusters
- Basic (0)
- Ota (25)
- Time (10)
- Identify (3)
- MsOccupancySensing (1030)
Endpoint 1
Profile: 49353
Input clusters
- Scenes (5)
- OnOff (6)
Referring to this earlier post regarding this device. It had been sorted out and have been working great.
But now I just installed new RS232 Zigbee device and noticed after repairing the units that I'm not able to configure this device anymore in the app.
Units (4 pcs) is paired correctly and i'm able to control and read status, but menu for configuration is not avaiable (wont work). All other devices is configurable still, also new paired devices after this popped up. Tried to unpair and pair, reboot system etc with no luck. I think it's a bug in the profile/Zigbee app.
Current device information read out of these today (if any changes du to new profile and app)
Develco Products A/S - SPLZB-131 - device information
Model: SPLZB-131
Device type: Router
Power source: Mains
Endpoint 2
Profile: 260
Input clusters
- Basic (0)
- SeMetering (1794)
- Identify (3)
- Alarms (9)
- OnOff (6)
- Groups (4)
- Scenes (5)
- DeviceTempCfg (2)
Output clusters
- Basic (0)
- Ota (25)
- Time (10)
- Identify (3)
Endpoint 1
Profile: 49353
Input clusters
- Scenes (5)
- OnOff (6)
Reported attributes
- currentdivisor_2: 1000
- currentmultiplier_2: 1
- currentsummdelivered_2: 0
- hapowerdivisor_2: 1
- hapowermultiplier_2: 1
- haactivepower_2: 0
- onoff_2: true
- rmscurrent_2: 0
- rmsvoltage_2: 24120
- sepowerdivisor_2: 1000
- sepowermultiplier_2: 1
- voltagedivisor_2: 100
- voltagemultiplier_2: 1
D
Check browser error console (F12) for any errors.
(01.12.2022, 07:13)admin Wrote: Check browser error console (F12) for any errors.
Find this in error console when i try push the config icon on the first 4 units, no errors when i open the other ones. The same both in mobile unit  (chrome for andriod, chrome for pc and edge browser in pc.
I have to mention its not my strengt to query/look for errors and i dont now what to look for here specific.
app.js.gz?v=20221102:1 Uncaught TypeError: Cannot read properties of undefined (reading 'clone')
    at Z (app.js.gz?v=20221102:1:23787)
    at String.<anonymous> (app.js.gz?v=20221102:1:24217)
    at Function.each (jquery.js.gz?v=20221102:2:2861)
    at Q (app.js.gz?v=20221102:1:24048)
    at Object.<anonymous> (app.js.gz?v=20221102:1:28873)
    at app.js.gz?v=20221102:1:28765
    at zb.showconfigmodal (app.js.gz?v=20221102:1:28922)
    at HTMLSpanElement.<anonymous> (app.js.gz?v=20221102:1:29291)
    at HTMLTableSectionElement.dispatch (jquery.js.gz?v=20221102:3:7537)
Z @ app.js.gz?v=20221102:1
(anonymous) @ app.js.gz?v=20221102:1
each @ jquery.js.gz?v=20221102:2
Q @ app.js.gz?v=20221102:1
zb.showconfigmodal @ app.js.gz?v=20221102:1
dispatch @ jquery.js.gz?v=20221102:3
r.handle @ jquery.js.gz?v=20221102:3
New fail also found:
.txt   logs.txt (Size: 9.07 KB / Downloads: 2)
My new RS232 Zigbee unit had a freeze up this morning.
I had to power cycle the RS232 zigbee unit to get it back up.
Attatching logs.
First my system error log is filled whith theese  lines;
lua: /tmp/tmp.zuUiif2Lpb/files/store/daemon/zigbee/lib/ctx.lua:191: ...tmp.zuUiif2Lpb/files/store/daemon/zigbee/zigbee/core.lua:813: ZB: could not start coordinator
stack traceback:
    [C]: in function 'error'
    /tmp/tmp.zuUiif2Lpb/files/store/daemon/zigbee/lib/ctx.lua:191: in function 'task_resume'
    /tmp/tmp.zuUiif2Lpb/files/store/daemon/zigbee/lib/ctx.lua:204: in function 'callback'
    /tmp/tmp.zuUiif2Lpb/files/store/daemon/zigbee/lib/ctx.lua:158: in function 'task_timer_run'
    /tmp/tmp.zuUiif2Lpb/files/store/daemon/zigbee/lib/ctx.lua:39: in function 'run'
    /tmp/tmp.zuUiif2Lpb/files/store/daemon/zigbee/app.lua:361: in main chunk
    [C]: at 0x0001496c
In addition i insert zigbee log (attatchment)
When it happen again, write to me to PM.
@clue9, ZigBee app has been updated, please check if it solves configuration issue with SPLZB-131.
(05.12.2022, 13:47)admin Wrote: @clue9, ZigBee app has been updated, please check if it solves configuration issue with SPLZB-131.
Tried now and seems to be solved.
Hi! My Aqara - Smart Plug is showing 10x the values on power compared to yesterday. Any ideas what to look for? I checked the monitor and the values there equals the values written to KNX.
@Rune, did this happen after ZigBee app upgrade or just by itself? What value do you get when reading status via UI?
@admin
From Zigbee monitor:  AttributeReports = [ { Attribute = { Type = int16, Value = 5540 }, AttributeIdentifier = 1291 } ]
The value 5540 is the same as written to KNX, I guess 10 x the actual value.
I got the last version of Zigbee app, but I can't remember when I updated it and if it is related to that.
Go to Control & status and click Read. What value do you get there?
Quite strange, did not do anyting and it seems that it fixed itself..
Latest app is updating all devices which have new profile on its own. Probably this happened.
Hi there.
Could you please add the TuYa ecosystem's two channel led dimmer support.
Manufacturer: _TZE200_gz3n0tzf
Model: TS0601
Device type: Router
Power source: Mains
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Groups (4)
- Scenes (5)
- 61184
Output clusters
- Ota (25)
- Time (10)
Feel free to ask additional logs if needed. Thank you in advance!
Unfortunately this device cannot be added because it does not follow standard ZigBee clusters but uses proprietary commands for control. It cannot communicate with other ZigBee devices directly unless a TuYa hub is used which will "translate" messages for it.
Hi and merry Christmas!
What are the odds for IKEA Fyrtur being added to the Zigbee list?
@Rune, it can be done. Do you already have them?
(27.12.2022, 12:39)admin Wrote: @Rune, it can be done. Do you already have them?
Yes, we bought two of them last week. I guess the Kadrilj series are the same? We got one of them to.
