Threads: 23
I really look forward to implement zigbee gateway on LM
Is there the possibility to be included in the Beta test on la LM5 lite (mx6)
Which dongle do I eventually Need?
I'm actually running zigbee2mqtt with a conbee II which I understand Is not supporter, but I do have a zzh (cr2652r) of Is supported
Regards
Marco
Threads: 35
To avoid any mismatch in HW and SW we prefer that any tester will purchase dongle from us. If you want contact our sales. Once you have it ask for software again.
Updated ZigBee app has been published in the app store. It is recommend to reboot LM after installation.
Can you provide a screenshot of the device list and device info for the leak sensor?
Do all water leak sensors that you've paired have the same cluster list?
The app has been updated. Check if you can map your water leak sensors to objects now.
Try resetting the plug and pairing it again. You've probably paired it before the power reading was implemented so the required configuration requests were not sent.
Threads: 18
That did the trick. Thanks!
However the previous associated object with 14.4 byte floating point showed a wrong value at first.
I had to set the object to something else and then set it back to 14.4 byte floating point to get the correct value.
Now everything is working fine.
Threads: 4
Hi.
Bought 4 pcs of Develco SPLZB-131 Schuko plugs with power metering.
I successfully pair these, but they won't operate on/off. and no power report to object is happening.
Device information;
Device type: Router
Power source: Mains
Receive when idle: Yes
Endpoint 2
Profile: 260
Input clusters:
- Basic (0)
- SeMetering (1794)
- Identify (3)
- Alarms (9)
- HaElectricalMeasurement (2820)
- OnOff (6)
- Groups (4)
- Scenes (5)
- DeviceTempCfg (2)
Output clusters:
- Basic (0)
- Ota (25)
- Time (10)
- Identify (3)
- MsOccupancySensing (1030)
Endpoint 1
Profile: 49353
Input clusters:
- Scenes (5)
- OnOff (6)
I also bought a namron zigbee 4 channel remote.
The remote only work for one group (all on/off/dim?),all buttons report to the same object, on off or dimm
Is there a way to utilize the group function on these remotes for controlling objects in LM without this direct accosiation between remote and other zigbee device in network. I have seen the same on the Phillips Hue Dimmer switch.
Also the scene buttons dont show up as a resource, not able to make any use for them.
Device information;
Device type: End device
Power source: Battery
Receive when idle: No
Endpoint 1
Profile: 260
Input clusters:
- Basic (0)
- PowerCfg (1)
- Identify (3)
- HaDiagnostic (2821)
Output clusters:
- Identify (3)
- Groups (4)
- Scenes (5)
- OnOff (6)
- LevelCtrl (8)
- Ota (25)
- LightingColorCtrl (768)
- LightLink (4096)
Endpoint 2
Profile: 260
Input clusters:
- Basic (0)
- PowerCfg (1)
- Identify (3)
Output clusters:
- Identify (3)
- Groups (4)
- Scenes (5)
- OnOff (6)
- LevelCtrl (8)
- Ota (25)
- LightLink (4096)
Endpoint 3
Profile: 260
Input clusters:
- Basic (0)
- PowerCfg (1)
- Identify (3)
Output clusters:
- Identify (3)
- Groups (4)
- Scenes (5)
- OnOff (6)
- LevelCtrl (8)
- Ota (25)
- LightLink (4096)
Endpoint 4
Profile: 260
Input clusters:
- Basic (0)
- PowerCfg (1)
- Identify (3)
Output clusters:
- Identify (3)
- Groups (4)
- Scenes (5)
- OnOff (6)
- LevelCtrl (8)
- Ota (25)
- LightLink (4096)
Both devices can be integrated but keep in mind that the current dongle cannot handle more than 15 ZigBee devices connected to it. Connecting more than 15 can brick the dongle and it must be re-flashed using an external programming device. We are working on an improved ZigBee-USB interface with an external antenna. It's based on a newer chip and can handle a lot more connections.
Currently it's not possible to make custom user profiles. We might implement this later though.
The direct pairing is for stand-alone mode without a gateway as devicea will form their own network for this. We will implement ZigBee groups later. Using groups you can control several lamps using a single switch and this connection will also work even if the gateway is offline.
Is it reported as "Mi-Light - Miboxer FUT039Z" in the app or differently? The profile uses device "manufacturer - model" pair to identify the device.
