05.04.2022, 11:11
@clue9, you didn't mention that the full manufacturer name for this device is "Develco Products A/S" so the previously added profile did not work for it. The next version will have this fixed.
Zigbee gateway integration
05.04.2022, 11:11
05.04.2022, 14:10
Could you please add support of this device?
Code: Manufacturer: frient A/S
13.04.2022, 14:21
Hello.
Is SONOFF ZigBee 3.0 USB Dongle Plus with a Z-Stack coordinator (CC1352P2_CC2652P_launchpad_*.zip v 20220219) supported out of the box with Zigbee app v20220322? Zigbee has a red dot in the status bar. As I understand, that dongle uses a different serial port /dev/ttyUSB0 (instead of /dev/ttyACM0 for CC2531). Is it possible to change the port or modify the Zigbee app configuration programmatically? Thank you in advance! HW: LM5 Lite + Ext (i.MX6) SW: 20211215 | Serial port list with a connected dongle /dev/ttyUSB0 ITead - Sonoff Zigbee 3.0 USB Dongle Plus Code: Apr 13 13:00:57 LogicMachine kern.info kernel: [ 241.041921] usb 1-1: cp210x converter now attached to ttyUSB0
14.04.2022, 12:44
Our new ZigBee interface is based on a similar hardware but it has a different USB product id which app uses to detect the adapter. You can try changing the product id from ea60 to bee0 on Linux using this tool: https://github.com/DiUS/cp210x-cfg
Keep in mind that this a write-once operation so double check everything before changing the parameter.
18.04.2022, 11:24
(14.04.2022, 12:44)admin Wrote: Our new ZigBee interface is based on a similar hardware but it has a different USB product id which app uses to detect the adapter. You can try changing the product id from ea60 to bee0 on Linux using this tool: https://github.com/DiUS/cp210x-cfg Thank you, everything works fine! P.S. Device is based on a new CP2102N-GQFN28 chip. CMD tool working code is https://github.com/ilutchenko/cp210x-cfg...id-pid-set
Is the new zigbee usb stick (with external antenna) already up for purchase and if so can I order one. Best Regards, Tigi
20.04.2022, 08:20
We have fully working prototypes at the moment. Production devices should be ready in two months or so.
22.04.2022, 21:15
It would be nice if you add this to the Zigbee collection:
Aqara Mini Switch Manufacturer: LUMI Model: lumi.remote.b1acn01 Device type: End device Power source: Battery Receive when idle: No Endpoint 1 Profile: 260 Input clusters - Basic (0) - MultistateInput (18) - Identify (3) Output clusters - Basic (0)
25.04.2022, 14:19
@Rune, it can be added but only with raw value reporting. It sends a certain number for single/double press and hold/release events. A small event script will be needed to perform required actions based on the switch action number.
29.04.2022, 15:49
02.05.2022, 08:33
We don't have plans to support third-party adapters. Some might work if they are based on the same hardware as ours but this is not guaranteed. conbee has a different protocol so it's not supported.
« Next Oldest | Next Newest »
