Threads: 29
@tigi, new USB device is still in the works unfortunately. There will be an RS232 alternative as well and it might be ready sooner than USB.
@fleeceable, the network map might not show all active devices if they don't have a profile. Without a profile these devices do not periodically report their statuses so these devices are marked as offline. Signal/route information is not requested from such devices even though they can be actually online. You can try reading status manually via the UI then running network map again.
As I've mentioned before due to mesh network organization the signal strength is not really meaningful because it only provides info about the last hop.
Threads: 5
I am working on with my own flutter app right now. Is there any way I can open network state via lua script?
I use LM as Zigbee, KNX, Modbus, Bacnet gateway. Would be good if I can get somehow list of Zigbee devices and open/close network to add some new devices. LM and app communicates over MQTT so I can send data to my app quite easily.
