Threads: 12
I am working on with my own flutter app right now. Is there any way I can open network state via lua script?
I use LM as Zigbee, KNX, Modbus, Bacnet gateway. Would be good if I can get somehow list of Zigbee devices and open/close network to add some new devices. LM and app communicates over MQTT so I can send data to my app quite easily.
Threads: 13
Was it a dream or did I see a list of Zigbee products that is compatible with LM5? Can't find the link. :|
Threads: 1
Maximum paired devices limit reached: 15
Any hint to pair more devices with the cc2531 ?
Threads: 21
We tested this chip and it will fail completely if you do more. Not enough memory. With our new interface you will be able to do 50
Threads: 40
New interface uses RS232 instead of USB because it's more robust and allows longer cable length. It uses newer chip with more memory so it can handle more nodes on the network. It also has an external antenna connector so the signal range is also improved.
Threads: 21
Hi.. willing to know if there is a roadmap to integrate the following:
Xiaomi RTCGQ01LM motion sensor
Xiaomi MCCGQ01LM reed sensor
Eurotronic SPZB0001 TRV valve
Or.. is there a way to create personal profiles for unsupported devices?
I do have a few of them and they work good...
M
Threads: 40
@Zen, it should work out of the box but it might have some incompatibilities or other issues.
The first small batch of RS-232 gateways will be ready soon.
@emme, be careful with Xiaomi devices as they sometimes have non-standard behavior. If possible, choose a different manufacturer.
We've tried making Eurotronic SPZB0001 TRV valve work with LM but gave up because it's very buggy.
Threads: 0
Will the RS-232 gateway also work for Wiser4KNX?
Threads: 40
@Zen Send us an e-mail for more info.
@Kolargol Yes, it will be compatible.
Threads: 40
@CarlS, support for your device will be added in the next firmware. You will have to reset it and pair again for all features to work.
Threads: 40
Support for Aqara SSM-U02 will be added in the next version.
Threads: 0
I am testing Ledvance RGBW lights and the Lighting Colour cannot be changed. ON/OFF dimming and light levels work fine. Would it be possible to add support for this device?
Manufacturer: LEDVANCE
Model: PAR16S RGBW
Device type: Router
Power source: Mains
Receive when idle: Yes
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- Scenes (5)
- OnOff (6)
- LevelCtrl (8)
- LightingColorCtrl (768)
- HaDiagnostic (2821)
- LightLink (4096)
Output clusters
- Ota (25)
Endpoint 242
Profile: 41440
Output clusters
- GreenPwr (33)
