Zigbee gateway integration
Did not help. But my new 232 gw is on its way, so I need to start over anyway.
Is it possible to communicate with devices without a profile via script?
https://kb.logicmachine.net/libraries/zigbee/
(26.01.2024, 08:28)Daniel Wrote: https://kb.logicmachine.net/libraries/zigbee/
Yeah, I played around a bit with it, but if I want to try clusters and controls that are not listed, how would that work?
You can only do what is available here.
Hi, is there any way you can implement this?
Thank you
Manufacturer: LUMI
Model: lumi.airrtc.agl001
Firmware version: 0.0.0_0025
Device type: End device
Power source: Battery
Receive when idle: No
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- PowerCfg (1)
- Identify (3)
- 64704
- Time (10)
- HvacThermostat (513)
Output clusters
- Identify (3)
- 64704
Updated ZigBee app has been published. Most of the requested profiles are added. As usual when testing new profiles please reset the device and pair it again.
Hi @all,
would it be possible to add the following air quality sensor please? Is SE using the same gadget config database for their Zigbee gateway?
Many thanks!
Best Regards
Steffen
Manufacturer: frient A/S
Model: AQSZB-110
Endpoint 1
Profile: 49353
Input clusters
- Identify (3)
- Scenes (5)
- OnOff (6)
Endpoint 38
Profile: 260
Input clusters
- Basic (0)
- PowerCfg (1)
- Identify (3)
- PollCtrl (32)
- MsTemperatureMeasurement (1026)
- MsRelativeHumidity (1029)
- 1070
- ManuSpecificDevelcoVOC (64515)
Output clusters
- Identify (3)
- Time (10)
- Ota (25)
Reported attributes
- humidity: 52.0
- temperature: 24.70
- voc: 0
AQSZB-110 is already supported. As you can see it reports sensor values. Is something not working for you?
Help with the library. I can't read the values from the device.
my device:
Manufacturer: LUMIA
Модель: lumi.airmonitor.akn01
Firmware version: 2020 www.
Endpoint 1
Profile: 260
Input cluster
- Basic (0)
- Identify (3)
- SsIasZone (1280)
- PowerCfg (1)
Output clusters
- Ota (25)
Reported attributes
- - analog input: 79.00
- humidity: 34.8
- temperature 26.94
I'm using a script
zb = require('applibs.zigbee')
addr = 'A43A'
cluster = 0405
attributes = {"humidity"}
endpoint = 1
res, err = zb.cmdsync('gethumidity', '54ef4410009275b7', endpoint, cluster, attributes)
log(res)
but I always have test in the log on
02/13/2024 18:43:04
* nil
how can I read the temperature value from the device? will the aqua temperature sensors be fully added?
.txt   logs.txt (Size: 86.54 KB / Downloads: 0)
Hi, I need to test one zigbee device from LM5 with my USB CC2531.
Just upload the FW (CC2531_DEFAULT_20211115.zip) see these pages?:
https://www.zigbee2mqtt.io/guide/adapter...c2531.html
Or is some special FW required?
@AlexandrT, this device does not expose required clusters for mapping to work. Many Aqara devices have this "feature". Workaround will be implemented in the next app version.
@Patrik, it will work with the default firmware but we strongly recommend using our RS232 gateway. It has more powerful CPU and supports more connected devices.
I would be very happy if you add support for Agara Temperature and Humidity Sensor T1 soon, it is very functional, a good indicator of signal and power consumption.
Hi!
Could you add this charger? Amina S
Manufacturer: amina distribution AS
Model: amina S
Firmware version: 1.4.10
Device type: Router
Power source: Mains
Receive when idle: Yes
Endpoint 5
Profile: 260
Input clusters
- Basic (0)
Output clusters
- Ota (25)
Endpoint 10
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- OnOff (6)
- LevelCtrl (8)
- HaElectricalMeasurement (2820)
- 65255
Endpoint 242
Profile: 41440
Output clusters
- GreenPower (33)
Reported attributes
- calclevel: 32
- level: 32
- onoff: true
- prevlevel: 32
(13.02.2024, 08:03)admin Wrote: AQSZB-110 is already supported. As you can see it reports sensor values. Is something not working for you?
Hi admin,
Many thanks the most things working well, what is missing is the battery level. Is this possible to add? Many thanks for your help!
Best Regards
Steffen
This device does not provide battery level information, only battery voltage.
