Threads: 41
Basic lamps (on/off + level) will work without a profile. RGB/TC lamps require a profile to be added to the app. It's a trivial task and can be done quickly. We just need to know which manufacturer/model name is reported from the lamp.
Threads: 55
Hi at all,
I have a client with several thermostatic valves Ezviz.
This is the information:
Is it possible add in future upgrades?
Manufacturer: EZVIZ
Model: CS-T55-R100-G
Device type: End device
Power source: Battery
Receive when idle: No
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- PowerCfg (1)
- PollCtrl (32)
- 1796
- SsIasZone (1280)
- OnOff (6)
- HvacThermostat (513)
- MsTemperatureMeasurement (1026)
- 65216
- 65024
Output clusters
- Ota (25)
- 1796
Reported attributes
- calclevel: 0
- occupiedheatingsetpoint: 50.00
- onoff: false
- systemmode: 16
- temperature: 20.10
Threads: 41
It can be added but it will require some additional testing. Some features might not work - it reports system mode 16 but ZigBee standard only defines modes from 0 to 9.
Threads: 4
For a project i need this Product MHCOZY Zigbee température
I see the ON/OFF object but i don't see the temperature
Manufacturer: _TZ3218_7fiyo3kv
Model: TS000F
Device type: Router
Power source: Mains
Receive when idle: Yes
Endpoint 1
Profile: 260
Input clusters
- Basic (0)
- Identify (3)
- Groups (4)
- Scenes (5)
- OnOff (6)
- 57345
- 57344
- 61184
Output clusters
- Time (10)
- Ota (25)
Endpoint 242
Profile: 41440
Output clusters
- GreenPower (33)
Reported attributes
- calclevel: 254
- onoff: true
- prevlevel: 254
Threads: 41
@hocine, this device uses a non-standard cluster for temperature reporting which we don't support. To work with our gateway it must have MsTemperatureMeasurement (1026) cluster.
Threads: 44
Im using eWeLink - MS01 PIR sensor with zigbee, is ther any way to alter the timeout/on duration of the sensor from LM?
Threads: 41
You need to wake up the device just before running the script. Usually this can be done by pressing the programming/reset button on the device itself. If you are not quick enough then the device will go into sleep mode again and won't communicate.
