HomeLynk SW2.6.0 problem with download device via KNX IP/Tunneling after upgarde FW
Hello.
I have a problem after upgrading HomeLynk from 2.5.1 to 2.6.0
I can`t download device application from ETS to Zennio QuadPlus. Before upgrade everything was ok.
The process is stopped with timout when try to send MemoryExtendedWrite (S=8) telegram
My collegue have the same problem with the other HomeLynk in the another house.
In attach 2 files from ETS Group Diagnostics when send via HomeLynk and via BAOS773
ThankYou
.zip   ETS-Connection-log.zip (Size: 55.18 KB / Downloads: 6)
Install this
https://we.tl/t-bgOfjUc38R
(28.04.2021, 11:35)Daniel. Wrote: Install this
Thank You, now it works.
For what devices (HL, SL) and hardware version I can use this patch?
Will work on all
What kind of file is it, what does do it and when will help this?
Utilities - Install update
