zwave - write to bus / polling
In the basic device properties i can set:
- write to bus
- polling
what do these parameters?
Even when i unclick the write to bus parameter, the values are written on the bus?
Write to bus - if checked it send telegram to KNX bus and updates local DB, if not, updates only local DB. We will double check if this works correctly in latest version.
Polling - not all Zwave parameters supports this. OpenZwave doesn't answer to a questions which does and which doesn't.
Correction: disabling "write to bus" blocks only writes to KNX/TP but it still sends telegrams over IP. If you are monitoring KNX bus via LM, you will still see all telegrams.
(30.06.2016, 09:58)admin Wrote: Correction: disabling "write to bus" blocks only writes to KNX/TP but it still sends telegrams over IP. If you are monitoring KNX bus via LM, you will still see all telegrams.
I monitor the telegrams with another ip device, but i see the messages and i have disabled "write to bus"
Thanks for bug report, it looks like write to bus is triggered even when this option is disabled. I'll ask the devs to fix it.
