Threads: 25
Is there anyway to for example export object (virtual) from LM to ETS?
Mainly thinking about my modbus and bacnet objects.
I have a IP interface connected to the bus, I want to use this for implement web app.
Threads: 31
Virtual objects are out of KNX range, this is impossible.
Threads: 31
Try creating such group address in ETS
Threads: 3
Another case i've been thinking of, is if you map your modbus registers to knx group addresses, and then want to setup a knx project afterwards.
Will it be possible to export a group address xml from the LM5 to import in ETS?
Best regards
Christian
