Threads: 67
Hello.
Is it possible to add several filter parameter at once in "Object Filter"? I want to filter both adresses in the range "5/0/*" and "6/1/*" at the same time.
Threads: 35
No this is not possible. You can tag your range and then filter by tag
Threads: 35
(02.06.2021, 08:43)khalil Wrote: (02.06.2021, 08:17)tomnord Wrote: Hello.
Try 5/0/*,6/1/*
I've learned something new
Threads: 67
Cool,, thanks. I see this only works with GA, not when filtering by Name and wildcards.
Multiple filtering is only possible with group addresses but not names. As Daniel suggested for more complex filtering you should use tags.
Threads: 20
you also can open an second window with a another filter.
yes it isnt what you did asked, but maybe easy enough.
