Modbus TCP Read Failed
Hello Dears
I have a Siemens Logo PLC modbus act as Modbus Srever
and I have two clients LM and Enterprise server from Schneider electric
I got these errors in the LM error log:
read failed: Broken pipe
read failed: connection reset by peer
first is it possible to have two clients in modbus TCP, if yes how to accomplish it without errors?
regards,
Best Regards,
It is possible to have many modbus clients but it is fully up to the modbus server to handle. Try enabling persistent mode. Reboot your PLC and see it this helps.
(10.06.2021, 09:08)Daniel. Wrote: It is possible to have many modbus clients but it is fully up to the modbus server to handle. Try enabling persistent mode. Reboot your PLC and see it this helps.
thank you Daniel for your reply
I was using the same port for the two clients, which makes the issue
regards,
Best Regards,
