Threads: 67
Hi, I have several LM's connected on the same vlan. They are used as BACnet GW and for remote programming. I get telegrams going between buildings, I suppose this is due to multicasting? Would the solution to avvoid this be setting up the IP interface from TP-UART to IP-Tunneling?
If you change the connection mode then LM won't be able to access the local TP interface. If you still need the ability to connect to each LM via Tunneling and avoid multicast communication you can simply change the multicast address to something different on each LM.
