LM DALI RGBW DT8
Hello
I use the Logic machine controller to control DALI Color Lights.
But I can't find RGBW Objects in the LM, while I can using another DALI controller.
So does the LM Support DALI RGBW DT8?
if not is there a way to do it with LM?
Best Regards,
Can you specify which KNX DPT are you looking for? We have:
12.600 RGBW color
250.600 3 byte DALI brightness and color temperature control
251.600 6 byte DALI RGBW
(05.07.2021, 13:20)Daniel. Wrote: Can you specify which KNX DPT are you looking for? We have:
12.600 RGBW color
Hello Daniel
I need 251.600 6 byte DALI RGBW
But From LM DALI Itself not via external third party DALI GW
Best Regards,
The internal DALI does not support this. Our CanX DALI does.
https://openrb.com/canx-lora-dali-gateway/
(05.07.2021, 13:34)Daniel. Wrote: The internal DALI does not support this. Our CanX DALI does.
Where can I find the full manual for the CanX DALI
nothing mentioned about RGBW, DT8 in the link above.
Best Regards,
Check the link I sent you. I have DT8 connected on my panel, works fine.
For built-in gateway you can control RGBW via a script: https://forum.logicmachine.net/showthread.php?tid=1698
