06.07.2021, 18:55
Hello
I have reactor V2 and starting from couple days ago there is no interaction between Reactor and the other KNX equip in the building.
After some investigation I think there is a problem with the KNX bus from the Reactor. I verified the wires, I restarted couple times and also factory reset ant restore the configuration.
Nothing works
I attached a prtscr from knx statistics
What can I do? There is a hardware problem? can be fixed or I need to replace entire reactor?
Thank you
Nothing works
Thank you
