MOSAIC VARIABLE 4 BYTE FLOAT
i am using mosaic and i should be able to modify a 4 byte float value but i can't find any suitable widget should i create it?
Thank you
Use Widget creator and add value element.
(30.07.2021, 14:35)Daniel. Wrote: Use Widget creator and add value element.
Hello
Using value element, I have integer value, while I would need the possibility of varying even decimals, is it possible to also have decimals in value element?
thank you very much
The only option I see is to use the +/- element but the minimum step is 0.1
