Mosaic restore form SCHNEIDER
Hello
I had to replace a wiser with a LogicMachine, no problem regarding visu and script, but also having backed up the schneider when I import it into LogicMachine I lose MOSAIC, I also tried to backup to json files from the schneider mosaic but when I import it into LM I miss some things and the icons do not match, is there a particular procedure to be able to migrate mosaic?
Thank you
In recent SE release they implemented some features which could brake compatibility between Mosaic and Touch. We can't guarantee for this to fully work. The only way to port it is via json. Touch use different DB storage than Mosaic.
