Multiple Trends issue
I have to values in cm when I show them in a multiple trend view I got two y-axes which are annoying
Best Regards,
If both objects have the same units then they should be displayed on the same Y axis. Maybe you have a space character before/after units in one of the objects (" Cm" or "Cm ") so they are treated as being different?
(23.08.2021, 07:18)admin Wrote: If both objects have the same units then they should be displayed on the same Y axis. Maybe you have a space character before/after units in one of the objects (" Cm" or "Cm ") so they are treated as being different?
aha the issue in the space
thanks admin
Best Regards,
