HVAC auto-switchover between cooling and heating using weather forecast
I have a thermopump that can be put in either cooling or heating mode - I want to design a logic that will automatically decide when to switch the modes and do it, instead of requiring manual switchover.
My idea is to use a script that runs daily at midnight - it will calculate the average temperature for the next 7 days, and use thresholds - if avg temp is less than X, then activate heating, if more than Y, then activate cooling.
One immediate question that comes to mind is - if it were the right thing to do, maybe the vendor of the heatpump would have provided such an 'auto' mode - but they didn't, so perhaps i'm missing something here and there's a reason not to do it.
Has anyone seen/implemented similar logic and can share from their experience of whether or not it 'works' for the comfort of the owner to not have to switch between the modes manually, or perhaps it will cause more harm than good somehow?
Thank you!
Morkov
(29.08.2021, 12:19)morkovka Wrote: Hi,
Don't do that. It may sound like a good idea, but it really isn't.
1. If you have a heat pump, you also have a nice insulated building with minimal heat losses.
2. Weather forecast is never 100% accurate, you'll miss a lot.
3. It's easy to click on a heat/cool mode icon once in six months, do you really need that level of autonomy?
If you really want to automate this part, then better work on an algorithm that will calculate your heat/cool demand (0-100%). When you have your numbers, it's easy to switch the heat pump mode. But this numbers will give you something much better - now you can modulate the heat pump itself, if it's not fixed.
You should also develop a heating curve based on outdoor temperature, for example T_out=10 > T_flow=25, T_out=0 > T_flow=30. Then you can modulate this curve based on heat demand. Tweak until you are satisfied.
Demand can be calculated as simply as counting the total number of valves in the system, and checking how many are open. Better way is to add weight to each valve, because it's not the same if it's controlling a 5 sqm bathroom or 25 sqm room. Some thermostats also have a "demand %" output, you can use that in the same way. More complex methods are looking at the difference between setpoint and actual temperature. Bigger the diffence, bigger the demand value.
Sorry I couldn't give you a working code, I never implemented this in LM.
Edit:
Sorry, I didn't saw the date of the original post.
