Direct input steps - change color
Hello everyone,
I'm new here.
Please I want to know how to change the color of the direct input steps icon ( color of the background, color of the number between the + and -,  and the color of the + icon and - icon  )
in the bellow pic of the direct input that I want to get.
 thanks in advance
You can enable "Use dark theme" in Utilities > Vis. Configuration. Also see this for CSS examples of spinner element customization: https://forum.logicmachine.net/showthread.php?tid=516
(10.09.2021, 09:33)admin Wrote: You can enable "Use dark theme" in Utilities > Vis. Configuration. Also see this for CSS examples of spinner element customization: https://forum.logicmachine.net/showthread.php?tid=516
Hi again,
Thanks for your reply,  the dark theme didn't work.
I changed the color with this CSS code.
.control-spinner .btn {
  background-color: #2b2a22;
  background-image: none;
  border-color: #2b2a22;
the middle part is white, how can I change it?
Dark theme works, you probably need to clear browser cache
(10.09.2021, 10:00)Daniel Wrote: Dark theme works, you probably need to clear browser cache
YES, Thank you so much.
