Script help
Could you please help me with one resident script?
If the temperature is below "A" for more then "B" seconds/ minutes turn on 1/1/2. If the temperature is above C for more then "D" seconds/minutes turn off 1/1/2
We have temperature with address 1/1/1.
Modify as needed, make sure that step value is the same as script sleep time (at least 5 seconds, can be more if the wait time is larger).
temp = grp.getvalue('1/1/1')
-- temp limits
temp_low = 20
temp_high = 30
-- time in seconds
time_low = 20
time_high = 40
step = 5 -- script sleep time in seconds
if temp < temp_low then
  timer_high = nil
  if timer_low then
    if timer_low < time_low then
      timer_low = timer_low + step
      if timer_low >= time_low then
        grp.write('1/1/2', true)
    timer_low = 0
elseif temp > temp_high then
  timer_low = nil
  if timer_high then
    if timer_high < time_high then
      timer_high = timer_high + step
      if timer_high >= time_high then
        grp.write('1/1/2', false)
    timer_high = 0
(20.09.2021, 10:52)admin Wrote: Modify as needed, make sure that step value is the same as script sleep time (at least 5 seconds, can be more if the wait time is larger).
-- temp limits
temp_low = 20
temp_high = 30
-- time in seconds
time_low = 20
time_high = 40
  timer_high = nil
  if timer_low then
    timer_low = 0
  timer_low = nil
  if timer_high then
    timer_high = 0
Thank you very much!
