Go-to statement
(08.05.2021, 19:29)fabiorusco Wrote: Hello,
I need use the goto statement for avoid to execute some commands.
How I can implement it?
Fabio
I have created some script for turn on and off the light of a garden, some of this are inserted in more comand (see the picture).
When I turn on there are no problems, When I turn off i need to control if one of the lamps are on by another command. This situation it's too much slow and the costumer want avoid this. Can you help me please.
Best regards
Script:
for i, object in ipairs(grp.tag('ccGPAL')) do
  if not object.data then
-- Accendo LED accendo tutte le luci
    grp.write('0/1/110', true)
    os.sleep(0.2)
    grp.write('6/0/30',true)
    os.sleep(0.2)
    grp.write('6/0/31',true)
    os.sleep(0.2)
    grp.write('6/0/32',true)
    os.sleep(0.2)
    grp.write('6/0/33',true)
    os.sleep(0.2)
    grp.write('6/0/34',true)
    os.sleep(0.2)
    grp.write('6/0/35',true)
    os.sleep(0.2)
    grp.write('6/0/46',true)
    os.sleep(0.2)
    grp.write('6/0/47',true)
    os.sleep(0.2)
    grp.write('6/0/58',true)
    os.sleep(0.2)
    grp.write('6/0/59',true)
    os.sleep(0.2)
    grp.write('6/0/60',true)
    os.sleep(0.2)
    grp.write('6/0/61',true)
    os.sleep(0.2)
--Flash LED
    grp.write('0/1/110', false)
    os.sleep(0.4)
    return
-- Spengo il LED
-- controllo 1° gruppo
G1=0
for i, object in ipairs(grp.tag('ccGEA')) do
goto passo11
G1=1
::passo11::
os.sleep(0.1)
for i, object in ipairs(grp.tag('ccGEP')) do
goto passo12
G1=1
::passo12::
os.sleep(0.1)
for i, object in ipairs(grp.tag('ccGIP')) do
goto passo13
G1=1
::passo13::
os.sleep(0.1)
for i, object in ipairs(grp.tag('ccGPPC')) do
goto passo14
G1=1
::passo14::
os.sleep(0.1)
for i, object in ipairs(grp.tag('ccGPPG')) do
goto passo15
G1=1
::passo15::
os.sleep(0.1)
for i, object in ipairs(grp.tag('ccGPPL')) do
goto passo16
G1=1
::passo16::
os.sleep(0.1)
for i, object in ipairs(grp.tag('ccGPPO')) do
goto passo17
G1=1
::passo17::
if G1==0 then
  grp.write('6/0/30',false)
  os.sleep(0.2)
  grp.write('6/0/31',false)
-- controllo 2° gruppo
G2=0
goto passo21
G2=1
::passo21::
os.sleep(0.1)
for i, object in ipairs(grp.tag('ccGEB')) do
goto passo22
G2=1
::passo22::
os.sleep(0.1)
goto passo23
G2=1
::passo23::
os.sleep(0.1)
for i, object in ipairs(grp.tag('ccGPBC')) do
goto passo24
G2=1
::passo24::
os.sleep(0.1)
for i, object in ipairs(grp.tag('ccGPBL')) do
goto passo25
G2=1
::passo25::
os.sleep(0.1)
for i, object in ipairs(grp.tag('ccGPBO')) do
goto passo26
G2=1
::passo26::
os.sleep(0.1)
goto passo27
G2=1
::passo27::
os.sleep(0.1)
goto passo28
G2=1
::passo28::
if G2==0 then
  grp.write('6/0/32',false)
  os.sleep(0.2)
  grp.write('6/0/33',false)
-- controllo 3° gruppo
G3=0
goto passo31
G3=1
::passo31::
os.sleep(0.1)
goto passo32
G3=1
::passo32::
os.sleep(0.1)
goto passo33
G3=1
::passo33::
os.sleep(0.1)
goto passo34
G3=1
::passo34::
os.sleep(0.1)
goto passo35
G3=1
::passo35::
os.sleep(0.1)
goto passo36
G3=1
::passo36::
if G3==0 then
  grp.write('6/0/34',false)
  os.sleep(0.2)
  grp.write('6/0/35',false)
-- controllo 4° gruppo
G4=0
goto passo41
G4=1
::passo41::
os.sleep(0.1)
goto passo42
G4=1
::passo42::
os.sleep(0.1)
for i, object in ipairs(grp.tag('ccGPAC')) do
goto passo43
G4=1
::passo43::
os.sleep(0.1)
for i, object in ipairs(grp.tag('ccGPAO')) do
goto passo44
G4=1
::passo44::
os.sleep(0.1)
if G4==0 then
  grp.write('6/0/46',false)
  os.sleep(0.2)
  grp.write('6/0/47',false)
-- controllo 5° gruppo
G5=0
goto passo51
G5=1
::passo51::
os.sleep(0.1)
for i, object in ipairs(grp.tag('ccGPEL')) do
goto passo52
G5=1
::passo52::
os.sleep(0.1)
goto passo53
G5=1
::passo53::
os.sleep(0.1)
if G5==0 then
  grp.write('6/0/58',false)
  os.sleep(0.2)
  grp.write('6/0/59',false)
-- controllo 6° gruppo
G6=0
for i, object in ipairs(grp.tag('ccGP')) do
goto passo61
G6=1
::passo61::
os.sleep(0.1)
goto passo62
G6=1
::passo62::
os.sleep(0.1)
for i, object in ipairs(grp.tag('ccGPEC')) do
goto passo63
G6=1
::passo63::
os.sleep(0.1)
for i, object in ipairs(grp.tag('ccGPEG')) do
goto passo64
G6=1
::passo64::
os.sleep(0.1)
goto passo65
G6=1
::passo65::
if G6==0 then
  grp.write('6/0/60',false)
  os.sleep(0.2)
  grp.write('6/0/61',false)
--Flash LED
os.sleep(0.4)
You don't need to use goto here. You should replace it with tag_or function if you want to check if a least one of tagged objects is ON. See this: https://forum.logicmachine.net/showthrea...961#pid961
It's hard to understand from the code what exactly this script is doing. Can you explain the task in more detail?
