LM4 dead?
Hello!
I cant connect to this LM4 and unfortunatly there is no backup. Is there somehow i can backup the SD-card and use it in a LM5?
[Image: 3E0gyUg.png]
If you have access to Linux then you can simply copy files from the 3rd partition from one card to another.
(23.09.2021, 12:09)admin Wrote: If you have access to Linux then you can simply copy files from the 3rd partition from one card to another.
And if I dont have access to Linux  Huh
Install VirtualBox and run Linux in a Virtual machine. Mounting Linux file system drives is also possible in Windows preview builds: https://github.com/MicrosoftDocs/wsl/blo...nt-disk.md
So we tried to backup the image from the card and it was successfull. We then restored it to a new sd-card with this tutorial -----> https://openrb.com/reflash-logicmachine3...-software/
That didnt help. The red LED, as shown in the image, is turned on but the LED in RJ45-port doesent turn on and we cant ping the LM4.
Did you try to use empty image as it the tutorial?
