Threads: 8
hey guys, i have a question.
I have the W4K / SW: 2.6.2 / HW: 2.X
The CPU / IO laod is permanently above 1.30
This is due to the Cloud Connector and IoT for the Alexa APP.
How much would the CPU / IO load go down if I buy the W4K HW: 3.X ... is it worth the change?
Can you install the Processes app from the store and tell what CPU load do you get?
Threads: 31
We will pass it to SE as there is nothing what we can do.
Threads: 24
Hi @all,
I having the same problem with HW 3.1 and firmware 2.6.2. The CPU load is permanently above 0.8 due to the API3 and cloud connector apps. All other processes / scripts are nearly zero.
Is there an update or feedback from SE?
Many thanks.
Best Regards
Steffen
Threads: 31
This part is fully done by SE, nothing we can do here. Contact SE support.
Threads: 24
18.09.2022, 18:33
(This post was last modified: 18.09.2022, 18:35 by pioneersteffen.)
has anybody heard something from Schneider Electric if they will improve the API3 and cloud connector apps in the near future?
It is really crazy: if I deinstall the apps the machine is running on 0.1 load with the apps I’m most of the times between 0.9-1.1.
I’m hoping for the upcoming Light&Building in October. ?
Many thanks in advance!
Best Regards
Steffen
Threads: 8
New FW (2.8.0) is planned end of this month (at least according latest info i have) and will include the improved / optimized versions of both apps.
Threads: 24
Thank you Erwin for the insight! I push the dumps and will let you know what the effect of the new firmware is.
Threads: 0
Exactly as Ewrin told. FW 2.8.0 is coming with new and much more stable versions of the CC and API T3.
Regards
Threads: 24
Hi guys,
I updated this morning to firmware 2.8.0 and the new apps and the load is much better. The W4k is running at 0.2 before it was 0.9-1.1. Excellent work, many thanks!
If the promises EEBUS feature is also coming finally than I would be completely happy! ?
Best Regards
Steffen
Threads: 0
Great feedback, thank you!
About the EEBUS - right now our focus is more on Energy management with OCPP.
EEBUS is evaluated by the management.
Regards
David
