Use Lm3 to control your Yamaha Receiver using HTTP commands ( RX- V671)
Heart
Help me!
I have information about a device that can connect to control it via HTTP.
I want to control the Yamaha RX-V671 through Lm3.
Has anyone ever done it, or who can write a script to do it. Help me, I am very thankful!
I am new to Lm3! Should not be very understanding.
Https://github.com/a-lurker/Vera-Plugin-Yamaha-RX-HTTP
https://www.google.com.vn/search?q=V671_...e&ie=UTF-8
https://forums.homeseer.com/showthread.php?t=157837
Can you write a script to turn off or turn on the player via Lm3?
Select HDMI 1, Select Audio 1
Thank so much!
Maybe this?    I made this script to mute my receiver when i go out:
http = require("socket.http")
url_string = "http://192.168.0.43:80/YamahaRemoteControl/ctrl"
http.TIMEOUT = 5
value = event.getvalue()
if (value == false) then
post_request_body ='<?xml version="1.0" encoding="UTF-8"?><YAMAHA_AV cmd="PUT"><Main_Zone><Volume><Mute>Off</Mute></Volume></Main_Zone></YAMAHA_AV>'
elseif (value == true) then
post_request_body ='<?xml version="1.0" encoding="UTF-8"?><YAMAHA_AV cmd="PUT"><Main_Zone><Volume><Mute>On</Mute></Volume></Main_Zone></YAMAHA_AV>'
http.request(url_string, post_request_body)
Just change IP to your receiver and put the script in a event.
(17.05.2017, 15:51)Magnus Lindgren Wrote: Maybe this?    I made this script to mute my receiver when i go out:
http.TIMEOUT = 5
If someone is interested, I found out that more recent Yamaha receivers use this protocol; https://www.sdu.se/pub/yamaha/yamaha-ync...otocol.pdf
TCPIP port should be 50000
A power on command would look like this:
post_request_body ='<?xml version="1.0" encoding="UTF-8"?><YAMAHA_AV cmd="PUT">@MAIN:PWR=On\r\n</YAMAHA_AV>'
Best regards
Eilert Bjerkan
