Threads: 1
Hello All!
I want to add spaceLYnk as a normal device to a KNX project.
To set up routing tables between IP routers.
How to do it right?
regards!
Threads: 31
SL does not have its own ETS application but you can add any other IP router in the place where SL will be connected. You can then export filter table from ETS and paste it to SL.
Threads: 1
Does SL have the ability to import filter tables?
Threads: 31
If you use an Ip router in the ETS in place where SL will be you can then right click on it and Preview filter table. You can copy it and paste it to SL where the filter table is. It will automatically put all group addresses.
