Threads: 44
Has it been any change in the Android App?
I've seen that my app has been updated to 1.0.6 version and now It seems that it can't connect remotely using the external IP and port forwarding...
Threads: 21
It seems wrong version was uploaded. We will work on it ASAP.
Threads: 21
Please check again.Double check if HTTPS is not enabled. This was the issue.
Threads: 21
Can you explain exactly what you are doing? I just checked local(Home) connection and port forward via Home connection and it worked for me. Remote.logicmachine.net is only and only for cloud nothing else.
Threads: 21
Make sure you updated app again, last updated 19 Oct 2021. I did as on the image and it works fine on data only as well as on WiFi.
Obviously cloud will not work without setting it up.
Threads: 44
Updated and working again!
Thanks!
Threads: 44
Hi again!
I'm still having some issues...
I have several LMs configured inside the APP and it seems that it only works when I check Autoload to one of them. When the app starts it is uploaded correctly, but when I go back and try to login to another one (clicking over its name) it doesn't work (sometimes black screen, sometimes 404 not found)
I have seen that it's only working the one that has Autoload enabled. If anyone has autoload I can't acces to any of them...
Threads: 21
We identified the issue and it is not related to autoload. We will fix it soon. If you want to make just one device working then uninstall the app and install again.
Threads: 21
New update again.
