LM5lite KNX Test and updated Documentation?
I have a LogicMachine lite installed.
I did the initial configuration and enabled KNX IP feature. Is it possible to thest the KNX Bus if the connection is ok?
Second small question  is there an updated Documentation?
Regards
Heinz
You will see KNX connection status in bottom right corner if TP-UART mode is enabled. Latest docs are on our site under each product.
Thank you. I got it.
I asked regarding the updated documentation because on the documents first page is noted "Document Issue 1.0
November, 2016".
Regards
Heinz
