Threads: 24
01.11.2021, 19:11
(This post was last modified: 01.11.2021, 22:00 by pioneersteffen.)
Hi @all,
I having two questions regarding Mosaic/touch 3 visu:
- Is there an option to scale the common widgets with a specific factor that two widgets fit next to each other on a IPhone 11 screen?
- Is there an option to connect custom widgets to google home or Amazon Alexa?
Many thanks in advance.
Best Regards
Steffen
Threads: 31
There are several widgets where you can select 1.5 size.
I don't get what do you mean by connect widgets to google, amazon alexa? Please take in to account that we have different implementation to SE so they are totally different.
Threads: 31
We just added to Mosaic Beta 'Scaling factor to mobile devices' in Settings & themes. It will scale the whole Mosaic accordingly, you can adjust it the way you want. 70% will fit two square widgets on iPhone.
Threads: 24
Hi Daniel,
many thanks for your quick reply again as always.
The scaling factor for mobile devices is what I’ve looking for. I hope SE will adopt this as well to a new version of their release.
Regarding my second question. I created several custom widget for example to control a lawn robot with the buttons start und stop. Is there away a way to connect this button to a google home or Alexa skill e.g. switch?
Another example is a thermostat custom widget with actual temperature and set temperature I want to connect to an existing skill.
Best Regards
Steffen
Threads: 31
If you use SE Touch then the answer is: I don't know. Our google/alexa implementation is totally different and you use separate app to set it up and you can do it in LM.
