HomeLynk lost objects and date time
Hello
I have an old V1.1 HomeLynk which lost the date time on a short time power cut.
today the power lost for less than 10 min and the date time lost, also I was added some scripts and virtual objects and all were lost!
does this mean that the capacitor failed?
regarding the added scripts and objects, where did it store, and how long time it takes to be stored permanently, and is there a way  to restore it?
Best Regards,
SD card is in read only mode and you must replace it.
(16.11.2021, 10:56)Daniel Wrote: SD card is in read only mode and you must replace it.
So its originally was in read/write mode?
but how it become in read only mode?
Best Regards,
It is common issue with very old devices, they switch itself. The old cards were not good enough.
(16.11.2021, 11:44)Daniel Wrote: It is common issue with very old devices, they switch itself. The old cards were not good enough.
Thanks Daniel
What is the recommended SD Cards?
Best Regards,
The best ones are the SLC ones 1GB is enough.
