Fibaro Door/Window Sensor + 1-wire DS18B20
#21
see screenshot
OK, so there is clearly something wrong with my Fibaro device. Or an incompatibility with the Z-Wave app...
If you have a rpi, you can install a domoticz image, thats also based on openzwave.
And the try if its see your device correctly.
(11.10.2016, 12:11)gjniewenhuijse Wrote: If you have a rpi, you can install a domoticz image, thats also based on openzwave.
I have both Rpi2 and 3. Under which OS works Domoticz? And does it works with the Z-Wave.me dongle, or how did you connect to the Fibaro sensor?
Domoticz is based on Linux, how to install: https://www.domoticz.com/wiki/Domoticz_R...i_SD_Image
Yes your dongle works, i have the same.
Attached is the Fibaro Door/Window user's manual, received from Fibaro with the message:
"Last firmware version of Door/Window sensor is 2.5, I’m afraid it is not possible to upgrade it from different gateway than Home Center 2 or Home Center Lite. You can try to ask your local reseller to help you in upgrading firmware, we have Exclusive Distributor in Sweden – www.gronahus.se, maybe they will help you with this topic."
I didn't had time to look lately into my problem, but it might be a firmware issue with my sensor. I need to check this first...
.pdf   FGK-10x-EN-T-v2.0.pdf (Size: 1.29 MB / Downloads: 8)
OK... it looks good in Domoticz.
I think there is something with the Z-Wave application inside LM4, it does not looks discovered correctly there...
(10.12.2016, 12:21)andeug Wrote: OK... it looks good in Domoticz.
Did you also receive the temperature in Domoticz?
Latest lm zwave app supports the latest door sensors
I need to buy another 1-wire temperature sensor, because the one which I've had it with this sensor I've connected it directly to my LM4 and sits now inside the electric panel.
Overall I think it looks better now. Did you changed some settings in the Device Properties "Advanced", so that you see the temperature in the "Basic" tab?
(11.12.2016, 19:43)andeug Wrote: I need to buy another 1-wire temperature sensor, because the one which I've had it with this sensor I've connected it directly to my LM4 and sits now inside the electric panel.
nope, i didn't change a parameter to use temperatures.
Hello, i have new door/window sensors and the same problem. But it looks like it has something todo with the include procedure. If i do the following steps it works for me:
- activate battery
- close sensor case
- set lm4 to include
- push the button on the bottom of the sensor 3 times (quick)
- wait for minimal 1 minute so all parameters are transfered (if you do not, then some parameters are missing and excluding of the sensor crashed the zwave deamon).
