firmware update
I have updated firmware in some
HW: LM5 Reactor GM KNX (i.MX6)
SW: 20211014
The firmware it seems updated but when I close the firmware window to actually see the version I get the error message attached in the screenshoot.
can i rest assured?
If you press OK then the system will try to upgrade the firmware. Then you will get this errors because the file field is empty. Nothing to worry about.
