Threads: 15
I'm preparing scada screen for my project. Total 130 visualition pages maybe i could add 10 more.
CPU I/O load rate is 3.79 4.00 3.83. Would it be a problem for user ?
Threads: 30
CPU I/O should be below 1, Ideally 0.7. Your device is overloaded and it will not work correctly.
The number of plans does not matter that much. What matters is the number of active user connections, bus load and scripts. As Daniel said your system is overloaded. Might be a script loop or a KNX/IP loop.
Threads: 30
Wait half an hour and tell us how it changed. How often do you run this script?
Threads: 15
CPU I/O level is now 0.7.And the Script running constanly.
Threads: 30
What is the timer set to?
Threads: 30
This is way too fast. Temperature isn't changing fast anyway. You can set it to a minute easily.
Threads: 15
Thanks a lot.Solved my issue.
