Threads: 17
Few months ago, we configured one Wiser with Alexa app and it works correctly.
After 2 months aprox. the system crashed and we had to restore a backup on the system.
All okai but the client said Alexa not working. We took a look on the configuration and we saw that effectively touch config was not restablished and cloud connector ant IOT T3 Api were not installed.
We did all the manual again to configure Alexa for Wiser (we did the same that the first time, two or three times), but now Alexa don't discover any device..
Schneider technical service tried to help with no succes.. (did the same like us)
Any help please?
Client is getting angry..
Thanks..
Threads: 4
15.12.2021, 14:59
(This post was last modified: 15.12.2021, 15:01 by Erwin van der Zwart.)
Can you backup your Touch3 configuration and clear all configuration in Touch3 and create 1 new control object and see if that “new” one is discovered?
Does Wiser for KNX remote app works normal (aka is the cloud connection working)?
Threads: 17
Thanks Tee,
Now the problem is that we Updated the firmware to version 2.7.0 and Touch config not working.. Error entering to config.
Phoned technical service and they will call us.
When they repair it, we will try your steps.
Thank you very much. I will inform you.
Threads: 18
Try clearing browser cache
Check if you have access rights if not admin is used. In this version user can have access per app.
Threads: 18
SE confirmed bug on their side, they already work on the fix. Only voice users are affected.
Threads: 17
Thanks guys!
Activated all points in the setting for user access and now we can join Touch Config.
Restored the final version of touch config and deleted objects until we had 20. Discovered the 20. The same steps for the others objects and now it's OK.
Very thankful.
Lot of problems with Wiser.. I'm not happy with SE, two/three months with this topic with no solution. Posted the problem on this forum and working in two days.. So much easier with LM.
Again, thanks!
Threads: 15
18.12.2021, 09:34
(This post was last modified: 18.12.2021, 15:47 by pioneersteffen.)
Hi @all,
are your blinds working correctly with firmware 2.7.0 and Alexa?
From my experience the position is inverted: 0% going to closed blinds and 100% to fully open. The same for the slats.
Many thanks.
Best Regards
Steffen
Threads: 17
Still having problems..
Yesterday at the afternoon all was OK. Today in the morning the client said to me it wasn't working.. Tried with my acc and not working.
Uninstalled APPS - Cloud Connector and IoT T3 API and now working again...
Some idea what's happening?
Threads: 18
You should report it to SE support. This part is 100% done by SE and nothing we can help here. Our LM Alexa and Google home are totally different and our own implementations.
